I have been using the following as my vocal chain for post-production cleanup in Reaper.
ReaGate
ReaEQ
ReaComp
Volume Adjustment
Master Limiter
It works well. Still, I have to do a fair amount of post-production around mouth noises and breathing, and purchased the following to help reduce the post-production time:
DeBreath
DeEsser
x-Click
My question is - where should I locate these three in the previous chain to be most effective?
Thanks
Noise management plugins are generally best to put first in the chain. The order you have them in seem quite reasonable. Though, there are times when you don’t always want to put them first.
One common situation is the need for a second desser to go after the compressor if it introduces more “ess” artefacts. You’d only want to do that if there is a problem in the first place
