InTrigger factory sample library
HI all,
Does anyone know how to get the sample library sorted for InTrigger?
I can’t a) seem to find it and b) **the instructions in the guide don’t seem to help at all.
**Keep getting the File Missing Pleas Relocate messages. Even after using the method in the manual.
Cheers
Hey @mattrixx,
Tech Support will soon follow up via email to further assist.
It seems there are a few presets that reference files that aren’t in the provided library. Most work fine for me, but occasionally there are individual samples that aren’t available.
Not clear whether the original poster is missing some samples or all of them.
(For what it’s worth, a sample browser in this plugin would be fantastic! The OS open dialog isn’t the best way to handle it. - ah, I see it works with Cosmos, which I don’t have on my LV1… explains it!)
I also do not have any of the samples showing up. I’m a full subscriber.
Thanks
Tech support got in touch and the problem is solved..
  1. Go to Waves Central > Install Products > All Products.
  2. Search for and select InTrigger, make sure the Samples options is checkmarked (Blue)
Bro i suggest you to relocate missing files to the correct library path, it may help in solving your problem
This the way. Central should install them in the default location you have nominated in Settings, along with your other Waves samples libraries. Or you can point InTrigger to the right directory in the menu on the top right of the plugin.
I’m in the same situation. Cosmos can find the regular Waves sample files, but the intrigger presets are coming back with “File missing Please Relocate” … I’ve searched all of the sample libraries and can’t find any “INT - ***” files
If you haven’t done this already, open up Central and select the Settings tab. Towards the top there should be a location listed as your default sample location. Try checking that folder. Also check the Waves default folder if you have custom location selected.
On Mac…
(system drive)/Applications/Waves/Data/Instrument Data/Waves Sample Libraries
Windows would be something very similar
Hey @nallegro,
If you still need assistance, please Contact Technical Support. They will gladly help out and save you the time and trouble.
