Would be great to have the ability to extend the LP and HP filters past the limits of the original desk.
Nice idea. Is this so you can use them for some kind of lofi/radio type of effect??
That would be one use yep, but I regularly have to reach for another EQ when I need just the bottom, or top end of a signal for separate processing. Or for example to filter out everything from 1k down on a tambourine.
The Brainworx SSL has a multiplier / divider button on the filters, which give you three times the range. (Still limiting, but I suppose keeps it within the SSL families feature set)
Remember the EV2 can host a second plugin so you can always insert another filter, or perhaps a multiband where you can also exploit the crossover points for this kind of thing
Unless this is a hidden feature I don’t know anything about, I’m guessing you’re confusing EV2 with Mixhub or some other strip?
Ah… yep. I am indeed confusing it with Mixhub and Scheps Omni
