It’s long overdue…we need this now more than ever with LV1 becoming more popular.
Ever considered the H-Comp?? It’s not quite a Distressor, but given that it’s Analog setting changes the compressor emulation it gives you like 5 compressors in 1. Which could be real handy in a live situation.
Try settings 1 or 2, slam it, add a bit of Punch back in and then use the Mix knob to blend it in parallel. For something more harmonically rich try Analog settings 3 or 4. It won’t replace a Distressor, but it will increase your sound sculpting options for sure.
Hopefully you’ll be able to come up with a fairly decent compromise.
Perhaps throw a distortion plugin in to the mix as well, especially if you’re wanting that to extra grit. Whatever you’ve got, but you can try looking at Manny’s plugin. And if you need to you can always put the two of them into the Studio Rack so you can use it’s Macros to create a much simpler, unified solution.
At least until they make something closer to a Distressor. There’s quite a few of these on the market already, so I’m not so sure Waves will just copy the crowd with that one as well. So you may need an alternative anyway.
They even created emulation of BSS-DPR 402 compressor which is great compressor. I think also a Distressor plugin would be nice fit to their Analog Emulation Plugins and believe there would be a lot of people who is interested.
Diggin this thread up: My A2 and I were talking about how usefull a waves distressor emulation would be today!
While there’s like a dozen LA2As and LA76s to choose form out there the Distressor options are far more rare and one of those are locked to the UAD hardware platform… Although that might not be the case any more.
Either way, a Waves Distressor would definitely be useful and get lots of sales I would suspect.
Here to resurface this conversation… would get a lot of mileage out of a Distressor plugin.
