Crash de Pro Tools avec Abbey Road J37, Mac mini
I bought Abbey Road J37 several months ago, but I’ve never been able to use it. I can insert it onto a track, but it consistently crashes Pro Tools when I reopen the session.
I’ve uninstalled and reinstalled it, cleared the cache, but nothing works. It was the same problem with Ventura, my operating system, and Pro Tools 2025.6.1. What’s the problem?
Did you check to make sure ProTools, your OS and your plugin version is compatible??
The other thing you can do is delete ProTool’s plugin cache, open up Waves Central and delete its cache in the Settings, then run the Repair function.
If that doesn’t work, try contacting Support
