I can’t believe this was missed in development.
So many producers (including myself, obviously) keep all their samples on a hard drive.
I have a hard drive with over a hundred folders of samples.
Am I expected to individually add a hundred different folders to the CR8 Sampler? That’s silly.
I have an internal H: drive that contains all the samples and libraries that I use frequently. I’d like to be able to just select the drive before using the CR8 Sampler because I’m worried about the ramifications of adding a hundred folders to the sampler, using it in projects, then removing those folders when drive support is implemented and having those projects break.
Plus adding 100+ folders would be a crazy waste of time.
