Cosmos is nice (once the bugs it has will be fixed, see the posts by other people). As a Window user, it is very important that you can also load Cosmos as a plugin into your DAW because very often, the DAW will grab the audio interface exclusively and then you can’t play back the samples from Cosmos through it while the DAW is running which kind of defeats the purpose. Other sample management tools like ADSR sample manager or Loopcloud can do that.
A workaround is to open it through CR8 because then the sound is played back through CR8. But that should not be necessary.
