Cosmos Feature Request
Hi - I’m very happy with the Cosmos update. There’s one aspect I’d love to submit as a feature request (unless it already exists in the plugin), When dragging/dropping from Cosmos within a DAW (Pro Tools in my case) would it be possible to attach a modifier key when dragging to either commit the BPM/Key change or if you don’t hold don’t the modifier key, the sample/loop will retain it’s original state
Also - I think as of now, it doesn’t have a commit Key/BPM feature too (unless i’m missing that) but would be amazing to have that
I don’t think there is a feature where it does retain the new Key/BPM info.
I know Logic does have a mode that allows it to ADAPT to what’s written in an audio file, this will also work with samples dragged over from Cosmos. I don’t know about other DAWs, though.
I suspect it would have to be a feature of the DAW as that is the application that is making the adjustments. Communication from outside the DAW is usually strictly limited as that reduces opportunities for hackers to exploit system vulnerabilities.
But maybe I’m wrong.
