The use of each plugin is relative to what side of the sound one may find themself
Please make the manipulation of harmonics in this plugin as not just additive but also subtractive
That is a very interesting idea @IamMrWes!
I will pass this on to our product team.
Actually I quite like this idea too.
While you’re at it, how about a Dual Mono and Mid/Side variation too
Very interesting point .
I somehow use the edge and Warm eq to subtract the harmonic effect when required.
When you add the harmonics you can easily check the band of frequencies added in an analyser .
If I don want a particular harmonic say 2k , I use the eq to reduce it .
I don’t know if this is accurate to your requirements but just thought of sharing .
Shine on…
