C1 Comp sidechain in cakewalk
Hi, I am trying to use the C1 with a sidechain in cakewalk and can’t even ling the sidechain up.
The way I normally add it is to create a send on the channel I want to use for the sidechain. adding the send brings a list of destinations, and I can’t see the “C1 Compressor Sidechain” there as a target.
I can see a “C1 Comp Stereo” if I add one of those, but that doesn’t off filtering on the sidechain.
What might I be doing wrong?
Thanks,
Paul.
Hey Paul,
You can try these next steps, if you’re still unable to set the sidechain up as demonstrated below, please Contact Technical Support directly for further assistance, they will be able to guide you through or remotely connect to your computer if that’s more convenient for you.
  1. Send to sidechain: Right click on the sending track (e.g. Kick), and from the Insert Send menu – select the sidechain input of the plug-in that’s loaded on the receiving track (e.g. Bass).
  1. Adjust send gain: In the mixer section, verify that the send is enabled and set the gain value to your liking.
Sorry - I couldn’t see how to add a pic - I think I have that figured. The full C1 sidechain doesn’t appear as a target for a send, but the standard C1 does.
Thanks for the suggestion
