hello I have a question about waves tune real time the plugin works only visually and nothing changes on the sound output and the vocal remains the same as on the input unchanged by the plugin I installed the same plugin on another computer connecting the same audio interface and microphone and everything works there without I’m asking for help, I’ve been stuck on this for 2 days and I don’t know what to do anymore
Hi @gibbs.kontakt,
Sounds like input monitoring is not on maybe?
You will need to enable the input monitoring in your DAW channel where you are using Waves Tune Real-Time to monitor the processed sound while recording.
If you are still struggling or can’t find it Contact Technical Support directly they will be glad to help out.
Hey, same problem here.
I have the input monitoring on and the pluggin recognices my voice but it doesnt apply. The scale, range and effects are active but nothing happens.
Hey @holipoi861,
Since input monitoring will vary from setup to setup, as we all work with different DAWs and audio interfaces, if you still need assistance, please Contact Technical Support You can also set a remote session with our support team, where they will be able to ensure it works as intended or guide via email, or a phone call.
If you’re trying to use it in real time make sure you don’t have “Direct Monitoring” active in your interface. The audio needs to be monitored via your DAW with Input monitoring active as Adi suggests.
Logic’sInput monitoring is activated by one of the buttons in the main toolbar. No idea how the others do it however.
