Problem briefly described:
LV1 Classic experiences bugs, when the showfile is built in the offline editor:
Fails to save and recall all connected preamp values (Gain and Mic/Line settings).
Switches scenes slowly.
Case:
Setup 1:
An isolated FOH LV1 Classic connected only to an MGO, with no SG-connection to any other SG-devices.
Showfile was created using the Offline editor (around march 2026). At the start of this production (around April 2026) this LV1 Classic was brand new.
Scenes are triggered via MIDI from LiveProfessor (via LTC). We observe a delay of approximately 3 seconds before the scenes actually change.
Every time the console is restarted, all local I/O preamp values must be re-entered manually (Gain and Mic/Line settings).
On the monitor LV1 Classic, the showfile was built directly on the console itself, and it does not exhibit these issues. All gain settings are saved, and scenes switch instantly (different but identical setup w. LiveProfessor/LTC).
Setup 2:
A completely different setup, involving a different artist, a different technician, and a different gear-supplier.
The setup consists of an LV1 Classic at FOH and two IONIC24 on stage.
The technician built his showfile using the Offline Editor (october 2026) and is now encountering the exact same issues:
Scenes take approximately 3 seconds to switch.
Every time the console is restarted, it has forgotten all preamp values across the entire SG network, requiring all gains and mic/line settings to be re-entered manually.
Reloading the showfile does not fix the error.
This LV1 Classic is about 1.5 years old, has been used on several tours, and has never had these issues before.
The only common factor between the two setups is that the showfiles were created using the Offline Editor.
