Hey I know you all are your own entity but with the Omni Channel, it has a slot to load other Waves Plugins. It would be really cool if you expanded that to load vst plugins also. Just a thought.
Totally agreed. SSL EV2, CLA MixHub and not to mention StudioRack would benefit from VST Support too.
The best you can really do is load two instances of Omni with your plugin of choice in between and deactivate any modules not in use. It’s not the same, but it’s the closest you’ll get at the moment.
