Increase Studioverse slot count
Please extend studioverse to support more than the current 8 FX slots - ideally with no restriction on the number of slots available to use in a single instance.
You could chain two instances together in your DAW, but then that doesn’t help if you want to encapsulate everything into one preset with one set of macros.
You could always use a parallel split and turn the second split off. It’s a little bit cumbersome, but it will work until Waves adds those extra slots.
