As above for trany/tube tone 1; why is the noise even as default there when using analog versions???
Hey @Aurasphere,
The Analog models provide the warmth and drive characteristic of analog
devices by enhancing certain harmonics and adding a small amount of
noise, you can set it to OFF to turn off the noise characteristics.
Yes of course…understood.
Are you saying that the choice is the same as the others but with simply noise added?
Yeah, the Analog dial selects both the classic characters of analogue compressors, but part of that is a low level noise characteristic. Turning it off though and you eliminate the other characterises too.
Personally I don’t mind it. It just gets a bit much when eery other plugin is also adding noise.
