H-Delay is causing a constant white noise
I’ve been having this problem where once I begin to add effects to a mix I’m hit with steady white noise. It persists whether I have the master effects on or off. I concluded that the white noise stems from H-Delay, which I have a few channels in my mix with H-Delay on. What can I do to remedy this? Thank you.
Hi @kanyedrofdeb,
You can switch the Analog parameter to off which will eliminate the white noise.
Although, it’s worthwhile mentioning that the Analog feature also selects the delay type emulation, 1 & 2 being an early analogue delay while 3 & 4 are tape emulations. They just also happen to make noise like the original devices.
Personally I don’t mind the noise in many situations. It adds an air of real equipment to otherwise sterile recordings. But then, I work with a lot of virtual instruments. Running things hard into a compressor/limiter will also bring up what is otherwise quiet noise too.
Its really comes down to a case of just choosing an approach thats best for you.
