There are many occasions where we receive mixes that have a rather ‘woolly’ bottom end with the bass and kick sounding muddy and indistinct.
If you find this pull up the LinMB, go to the low end control and reduce the attack to around 11ms. Pull the threshold control down until it is tickling the low end and see what you think. Bypass the band if you want to hear the difference it is making.
This is one of the approaches you are ‘not supposed to do’ but it works beautifully and introduces terrific clarity and punch to a woolly bottom.
Thanks for the Tip.
While Mastering i also try to isolate the Low end by Out the mix through a c4 , Soloing the first band to about 100 hz . I then duplicate the track with the c4, only this time Soloing the rest of the bands
That way now that i have the Low band kind of more approachable i can handle or control it better .
I use the Low air along with Mv2 especially for hip hop Masters.
sorry Kurma, missed this post. I don’t find any appreciable issues. I’ve used this approach for many years now and the proof of the pudding is in the listening. Also checking on analysers as well as listening gives you the reassurance. Try it and see and let me know what you think.
The other point of course is the rest of the mastering chain. I have one that has been developed over the years and it is my ‘go to’ and always includes the LinMB.
The other thing about the LinMB is it’s capacity to provide a result where the phase distortion has been attended to in the development of the plug. It is a beauty. The latency I usually find too much for the mix stage but in the mastering it is ideal.
