Flow Motion Sequence Not Rendering in Audio Export
Flow Motion Sequence Not Rendering in Audio Export.
The sequencer works fine during playback, but doesn’t render in export. All I get is the first note of the sequence over and over. I tried to automate the sequencer but got the same result. the sequencer is not playing the entire sequence either. the steps are somewhat muted not the full sound I get when just playing back. This shouldn’t be an issue at all. What am I doing wrong?
What OS & DAW??
It’s been a while since I tried this feature. How is it being Triggered?? Perhaps you can try the mode that requires you to sustain the note.
Well my solution was to physically trigger the sequence while routed to another track channel to capture the audio. it’s not ideal but gets the job done. Really I tried every possible configuration. Key, BMP and Host. “Key” got the playback right but I had to keep triggering the sequence over and over till I nailed the tempo. Very strange as I’ve only had issues with the Step Sequencer the Arpeggiator works no problem play back or export.
My OS is Win 11 and my DAW is Reaper Behringer I/O ASIO drivers
Make sure the Flow Motion sequence is properly linked and enabled in the timeline before exporting audio.
Not sure what you mean “Properly link and Enabled” I’ve watched several tutorial videos and this was never mentioned. Can you explain how to do that please?
Hey @kaku88,
One of our tech support representatives will soon email you to further assist.
The Flow Motion sequence is not rendering in the audio export likely due to missing effects or incorrect export settings check your mixdown and track routing.
Check your render settings and ensure the Flow Motion sequence is enabled and linked correctly in the timeline.
