eMotion LV1: Routing mix bus outputs to another instance of LV1
Has anybody found a way to actually route outputs from one LV1 mixer to another? As far as I can tell there is currently no way to take an output from a mix bus, main out, etc and receive it at another console on the same sound grid network.
Hi @gobberdouf,
A Live Sound representative should reach out soon over the email to advise on your routing inquiry.
Yes - in the routing matrix. “FROM”. and “TO”
Slightly different situation, but Waves had a video of someone with a Behringer card routing SG4K inputs direct to a Behringer which was used for monitors.
I’d be interested in which solution exactly you came up with. Honestly I still fail to see a way how to “mount” a FOH LV1 instance into a monitor LV1 instance e.g. for routing communication channels.
If you have a a Dspro 4000 you can use aes output use a xlr cable to the aes input now you can send 4 st o 8 mono channels!
