Digigrid D I/O settings related
Hi all,
I would to get advise and experience sharing for digigrid d interface io assigning matter. We know that this interface has inputs 1 and 2 which is use for mic/line and outputs 1 and 2 are monitor output. By any possibility if we want to:
  1. route input 1 to output 1 and route input 2 to output 2 of the interface for digigrid d processing.
  2. Is the digigrid d interface monitor volume control button is to control both output 1 and output 2 level equally(for example: if we turn the monitor output level to +5 dbu and both of output 1 and output 2 level will be increase to +5dbu at the same time)?
  3. Any additional io mapping need to be done in order to get the configuration by mentioned as item 1 above?(assign digigrid d input 1 ,2 and output 1,2 from superrack patch window) and (set the io mapping through digigrid d channel 1 input as digigrid d input 1 , digigrid d channel 2 input as digigrid d input 2; digigrid d channel 1 output as digigrid d output 1 , digigrid d channel 2 output as digigrid d output 2; )
Knowing that this topic might be boring but I really not able to get much relevant resources regarding this topic hence would like to get expertise advise.
Thanks in advance for the feedback. Many appreciated to the sharing and advise for this topic .
Regards,
Hey @tetsu81,
Yes, you can route Input 1 to Output 1 and Input 2 to Output 2 on the interface for processing. However, note that the Volume control affects both outputs simultaneously and cannot be assigned to control them individually.
That said, this type of routing setup isn’t ideal when using the DigiGrid D with SuperRack. I recommend reaching out to our Live Support team for more detailed guidance and routing assistance.
Hi team,
Noted with thanks and appreciated for the great helpful response for my inquiry . Will get the live support team for more details about my inquiry.
Regards,
