I have the new plugin from Waves, Curves Resole.
How to put on - where you can see the the LEARN button and others? I can’t put in on.
Thanks.
Thanks.
Hey @kppoykko,
You will need to load the Curves Resolve plugin using a DAW like Pro Tools, Logic, or Reaper.
If you are having trouble seeing it in your DAW or require any additional assistance or information, please Contact Technical Support directly.
The Learn button should be immediately visible when you load the plugin. You’ll need to select a track in the sidechain in order for it to analyse and adapt to the audio.
If you want to see the sidechain’s waveform you can click on the very thin brown arrow underneath the Learn button.
The ‘LEARN’ button is actually context-aware! It usually only appears when you have a sidechain input active. In most DAWs (like DaVinci Resolve or Cubase), you need to route another track (like your Kick or Vocal) into the sidechain input of the plugin first. Once Curves Resolve ‘sees’ that secondary signal, the Learn and sidechain-specific controls should pop right up in the UI.
Ah!! I never noticed that, good point!!
