Hello, I want to upgrade my PC and change the processor and RAM (only 2 things). How should I proceed to avoid problems with Waves Central and my plugins? Is it necessary to remove all before changing the processor?
Hi @marcoanl,
To avoid issues, I advise you to deactivate your licenses..
Once the upgrade is completed, you can reactivate your licenses.
If you need any assistance with setting everything up or need any additional information, do not hesitate to Contact Technical Support.
The processor and RAM shouldnt be an issue. However, it is super easy to run up Central to deactivate your licenses I’d be simply doing that as a precautionary method.
After all, I can’t be 100% right 100% of the time. ![]()
