Can't use waves plugins as favorites on Pro Tools
Since v15 my waves plugins set as favorites on my Pro Tools plugin list disappear from there after closing and reopening the daw.
Anyone?
No solution but I’ve noticed this too, and it started with the 2024.6 update to PT.
I suspect updating to the very latest Waves version would fix this, if you’re within WUP?
some of them are v15 and still don’t work :frowning:
Hmm. in that case I won’t bother WUPping yet, looks like a pro tools update issue!
If you cannot load your Waves plugins I recommend Contacting Technical Support.
If the plugins cannot be loaded or found specifically from your favorites folder it is worth verifying with Avid maybe.
Hi all.
This issue has been fixed in Pro Tools 2025.6 and Waves V16.
