Apple Compressor (Final Cut Export) Plugin Failure
I’ve noticed that when I send a file from Final Cut to export with Compressor, all my waves plugins are disabled. I don’t know if this is a problem with Apple or with Waves, however Waves 13 has been very… slow and hard to use with Logic Pro X and Final Cut Pro.
and the presets are extremely slow to load
Hi @MicaiahR Welcome to the Waves Forum :slight_smile:
Please note that Waves V13 plug-ins are not compatible with Final Cut Pro as mentioned on the Supported Hosts page.
You can consider rolling back to V12 which is officially supported with Final Cut Pro.
Refer to the How to Roll Back to Waves V12 article.
In case you need further assistance feel free to contact Waves Tech Support.
Thank you so much! I really appreciate your time!
Quick update. I found out that the plug-ins only crash when I export using Compressor. if I export directly out of Final Cut, all waves plugins work perfectly. I hope this information helps.
Nice :love_you_gesture:
I’m pretty sure it can help other users that encounter the same issue.
