Waves Plugin and Harrison Mixbus 6
Hi, I know that Harrison Mixbus 6 is not a DAW supported by waves, but I see that Mixbus load in regular mode the plugin AU Waves, but this does not work as well…
There is some tip or information about this?
Thank you so much
Hi @classicstudio and Welcome to Waves Forum :slight_smile:
You are correct, Waves is not supported in Mixbus environment.
This does not necessarily mean that it won’t work, just that our software was not designed for it nor tested and qualified to run with it.
Due to this fact, we do not have a knowledge-base of possible issues. It might work fine, but if it doesn’t we are not able to fully assist.
That being said, you can try different components, other than AU, such as VST or VST3. Perhaps they will operate better in your DAW.
Thank you very much Gurik!!!
