Hi All,
Have got a issue when try to run Supertone Clear on SuperRack Performer V14.30.283.991 Build R 312874.
The GUI is not showing anything on the display.
If I read the spec. it should work.
Technical Specs of SuperTone Clear:
Operating Systems
- macOS 10.13 and above (Native support for Apple Silicon)
- Windows 10 and above (64-bit only)
- Supported Plugin Formats
- Supertone Clear
- AU, VST3, VST, and AAX
- Supertone Air
- AU, VST3, and AAX (Audiosuite)
Sample Rate and Buffer Size
- 44100Hz, 48000Hz, and 96000Hz
- We recommend using an I/O buffer size of 256 or higher
