I’m sitting on a Protools computer/ OSX Ventura where the resize setting is not saved correctly. Every time I open a plugin the window is back to 100% . “150% Set as default” has no effect either.
Anyone experienced this?
Hi @dany_g,
Thanks for reporting I suggest to Contact Technical Support with the information you mentioned so they can further investigate this.
Also worth checking if this occurs only on specific sessions or even fresh one.
The size parameter doesn’t by any chance get saved with the preset?? That’s should be easy enough to test if that’s the case.
