Greetings. Was messing around with the NLS as I read it causes aliasing. Any chance of supersampling getting added? It would be a killer addition.
I certainly would like to see this too, but it only really poses a problem if the artefacts become audible. This extreme example results with aliasing down below -60dB which certainly has the potential to be audible, especially after compression. However, it is an extreme example.
A real world scenarios should see far less Although, many instances may amount to something more noticeable. If it’s a concern you can always roll off the super highs where it matters. before it hits the NLS. Personally, I’ve never really noticed it to be a problem running at 96k, but then, I like to use gates and LP roll-offs alot as well. Not because of aliasing, but it seems like it’s a good strategy nonetheless less.
Hi Simon, thanks for pitching in.
This test is actually just a clean 800Hz sinewave, with a modest drive setting and without clipping the NLS channel. Didn’t take an impossible amount to get the aliasing into the sub frequencies and below, even on 96kHz SR. So at 8kHz we’re already producing considerable aliasing down into the mids, on a single instance, even on this modest setting. Add NLS across an entire mix, crank up the drive, and one can start to imagine why some people find NLS to sound flatter than competitors solutions, it’s probably the aliasing.
But your tips are sound and you are right: We’re talking nuances here with light settings and responsible use. This is however what’s keeping me from setting up a virtual console with NLS, as I’d like to be able to use a lot of concurrent tracks, and feel free to actually drive those beautifully recorded consoles! My finicky workaround is to use a wrapper with supersampling, but this kills workflow if I want to change settings.
//Rob
Edit: I’m sure 96kHz samplerate projects work nicely, it’s just not feasible in my case.
It’s a catch 22 as oversampling can help minimise this, but at an increased overhead. Making it an option and putting it in the decision of the user’s hand is probably the most intelligent way to handle it.
Though, no recording system has ever been perfect, analogue or digital. You just and up swapping one set of artefacts for another. People might say the analogue artefacts are more pleasant, but that’s true only at extremely low levels. It can be just as damaging to to music too,
To be honest I’ve never noticed NLS to be “flatter” myself, but that might be the 96k thing. Sure it isn’t significantly better, but better is still better.
I would also love to see oversampling on NLS! It still is a great tool, that I use on a daily basis on hundreds of mixes.
+1 Oversampling for NLS and all other Waves products would keep me using waves plugins. At the moment I’m slowly moving to other developers that implement the features people are asking for.
Agreed! Also some GUI updates would be great
I am starting to look to other plugin makers with more upsampling options. How can u believe that the cla 1176 should run up to 192 but the cla mixhub that has a 1176 built into it should only go to 96? Just seems obvious that waves should increase all plugins to be capable of 192 and either give the plugin the ability to upsample 2x 4x. This would make wave sooo powerful when considering there prices.
It does seem a bit of an issue. Perhaps the reason why it’s capped at 96, though, is the horse power required to run it higher will just slow everyone’s computer down to a crawl. It’s already quite hungry at 96!?!
I have no problem running cla mh. Having the option to run one instance of the plugin at 192 on just my vocal track to take full advantage of the drive and 1176 combo seems like a no brainer. If u have cpu problems well all the more reason to give the customer the option to upsample or leave it be.
HD button please! for oversampling option
Oversampling please!
+1 for oversampling options. I’m using NLS in Metaplugin right now for 2x online/4x offline and it makes a significant difference. The downside of course being a workflow killer.
I think that there is enough here that is passionate enough about introducing an oversampling feature to NLS, it would probably be worthwhile to make a formal request through Waves Tech Support. The more voices that speak out, the more likely it will be introduced.
Good suggestion, I’ve sent them a message asking what’s required to get their attention, and suggested that this is a low hanging fruit that would strengthen their position against competing products. Let’s see how this unfolds
Good move. The more that request it, the better chance we have. I’m just hoping the others in here follow suit.
