NLS Channel Selection
I once saved my NLS settings as “default” and it was on Mike Channel 14. I don’t like how that anytime I load the NLS, all the Mike instances select channel 14. How do I get it back to the original default settings where the channels are randomized? I have deleted the whole waves bundle V14 and installed V15, but the situation remains the same. I have deleted my User presets for NLS but nothing changed. What do I do please? I am using Logic Pro on a MacBook Pro 2019.
Hey @edriver3,
Please Contact Technical Support they will gladly help out.
I did this myself quite a while back. You need to delete the Default. You would also need to delete any plugin default you name using the Logic’s system.
