LV1 MyFOH - Long Press to edit channel name text
Using MyFOH to mix monitors, if an engineer touches the channel name text it instantly presents a dialog to edit the text. This requires the monitor to keep cancelling and pressing elsewhere. Mixing the LV1 with V14 updates that is preferred touchscreen method as it was moved to the middle of the channel strip. (from the top)
So - can you change the MyFOH functionality so it requires a long press to update the text?
This is a great point. I second this.
Good point. Would also be great if the double tap to set the fader at 0db action could be turned off. Because it’s too easy to acidentally trigger it.
