Intrigger velocities are all over the place
Can we get an option for intrigger to not follow the velocities so precisely? a mode that gives a one shot every time would be great. if you crank the input on slate trigger that’s what it does. There’s no input on intrigger and no option if you uncheck all the humanize stuff for it to just be consistent.
Actually, there’s a Midi Out tab bottom left of the main plugin window. Click on the disclosure triangle and you can set how the tiggers translate to midi information. Here you can set the minimum value and set the velocity curve for the notes.
If you increase the minimum, and/or increase the velocity curve value towards 100 you can make the triggered sounds more consistent.
BRO!!! THANK YOU!!! What a stupid way they implemented that but that totally is what I needed. thanks a bunch!
Yeah I never noticed until now that it’s a little obscure. I’m surprised nobody picked up on that in beta testing. It is what it is I guess. Once you know it’s they’re and have maybe created a custom “template” it becomes a bit of a non-issue in the end.
