CLA Vocals plugin missing in SuperRack
Hello,
I have just installed demo version of some plugins, CLA Vocals included.
All of them are available in SuperRack except CLA Vocals. In DAW it’s visible.
Any suggestions how to fix it?
Thanks, Martin
I don’t use SuperRack unfortunately, so I’m not really in the position to be able to help. Perhaps someone else here would be of assistance.
Though if I ware to offer a conjecture could it be perhaps that it induces latencies too high to be of use in something SuperRack… maybe??
Response from support:
*As CLA Vocals is only available in Stereo/Mono-to-Stereo, please make sure you set the rack output in superrack to stereo (i.e 1-2). *
The plugin should then appear in the plugin list.
My fault :blush:
You can fall into that kind of trap with the way Logic handles its plugins too.
I’ve been caught out a few times myself. It’s like forgetting to plug the other end of the cable and wonder why you’re getting no sound!! :confounded::upside_down_face:
It’s similar with CLA Drums when using DaVinci Fairlight. It will only show up in channel effects rack for stereo tracks. Not available when using mono tracks. (…which I often use). :frowning:
Hi @gobrinton,
CLA Drums, as the CLA Vocals, exists also only in a Stereo plugin component.
Even though Da Vinici is not supported by Waves I believe that creating a Stereo track will solve the issue and you should be able to see the plugin.
Is it possible to use a plugin after a cla plugin that converts stereo to mono and allows the rack to choose mono as an output?
Some DAW’s, like Logic, allow you to mix mono and stereo plugins on the same channel strip. You would go about it in Logic by option clicking the plugin slot, that will then show both mono and stereo plugin components allowing you to choose whichever format you want.
I don’t know how other DAWs achieve it though.
