Broken? - Output Routing Scene Recall
Was building out some scenes to toggle an external insert in and out (quick bypass for outboard gear) and realized that the “External Insert” plugin was locked in recall safe and wouldn’t allow me to bypass it, even after going into recall safe and making sure that routing / output was bypassed it didn’t seem to fix it.
On the same note, when I tried building scenes for output recall (PANIC - Route IEM Mix 1 to BACKUP output channel) I noticed the same thing. Vritually all output recall is borked or disabled for no apparent reason. Posted to a few different groups on Facebook until someone responded back saying that output recall was disabled on v15 and never came back. I’m currently on the latest version of V16 + 80 channel mode.
Does anyone have a status update on this being re-enabled? I really need the ability to quickly bypass external inserts and change output routing in the event of equipment failure - even if theres a temporary loss in audio, having the ability to bail out of something is crucial.
I’ve experienced the same with changing input assignments and/or a simple input A/B swap with no success.
