AI Defeedback plugin on Soundgrid
Please partner up with alphalabs or develop your own ai defeedback plugin for soundgrid.
I won’t mind if it eats dsp for breakfast, we can still add additional servers.
Just purchased defeadback AI and running it with superrack performer as insert to lv1 works really good but I also want it to be installed directly on lv1 as they have done it with Dugan auto mixer they could easily buy it or work with the alpha labs to make it waves plugin
Thanks for the feedback! would you mind to share latency, hardware specs / soundcard? cheers!
I installed performer on the same computer with LV1 host
It is
ASRock Z690
Kingston FURY Beast 32GB (2x16GB) DDR5 memory
Intel Core i7-13700K
Latency is 4.5ms
I inserted it in the channel as first plugin as external insert
The plugin actually uses less than 1percent of cpu
A low latency version of the Clarity Vx would be awesome. Yamaha has a native plugin called DanSe that emulates a Cedar DNS on their DM7 series and Rivage series consoles. They use plenty of dsp but are indispensable. It would be great to see a Waves product like that.
Actually you can use it by using external insert on your waves superrack, just patch it properly by using Daw as external insert I tried it to use it on 9 individuals mic, but unfortunately there some huge errors when using only lead mic when I using it to sermon, still trying to figureout if what cause it. I don’t know if it because of the cpu peak but mostly it runs under 60 percentage of total usage with waves superrack
