waves central displays in the lowest resolution… I run triple monitors in my studio, waves central, now is spanning two monitors when it comes up, the window is NOT resizable
Dare you to take this seriously… waves central is not a well behaving application it takes over my monitors, and is unusable.
Hi @wmjsottile,
In case you have verified your setup meets our minimum requirements and your settings such as the screen resolution match the recommended one" Screen Resolution
Minimum: 1024x768 Recommended: 1280x1024 / 1600x1024" I suggest taking this forward with our Technical Support team they will be able to ensure everything runs as it should and hopefully save you some time.
