In the latest version of Bluecat Patchwork, the graphics of V12 plugins are all inverted as per below…
Weird!!
Weird!!
Hi @mattrixx,
Wow that is very odd. In this case there is not much I can to to offer help as Bluecat Patchwork plugin chainer is not officially supported, tested or qualified by Waves.
It was all working just fine prior to the V12 update however. (happening with both VST and AU versions)
Hi @mattrixx,
After some investigation I understand this issue occurs in 32bit host applications. If the DAW you are running or BlueCat itself is 32 bit, try a 64bit version if available. If not, perhaps some sort of bridge may help.
I hope this helps. Once again I must say that Bluecat Patchwork plugin chainer is not officially supported, tested or qualified by Waves, therefore I cannot guarantee this will work or offer any assistance beyond this advice.
Interesting, as this occurs when running Patchwork in Catalina which is 64bit only. I am so it’s running in 64bit.
I see that Patchworks has two varieties to install 32 bit and 64 bit. perhaps you are using the 32bit component in a 64bit environment?
Again - it is not supported by waves, so this is not something we can currently fix if that is not the issue.
I am just trying to help with what I can
That is not possible in Catalina. 64 bit only.
Copyright © 2022 Waves Audio Ltd. All rights reserved. Contact Us | Terms & Conditions | Privacy Policy
