Added several sample folders, waited for scan to finish, once completed I looked through the samples and a large portion of them were blank waveforms, with no attributes (therefore excluding them from the main “cosmos” view), almost as if it haven’t finished scanning. However, COSMOS appears to be done (option to ‘pause scan’ reverted to ‘rescan’).
Some of these samples are similar/identical to others that showed up fine, so I don’t think it’s a problem with the AI not being able to categorize the sounds. Rather it seems to be a problem with the scanner as others have had similar issues.
Attached image depicts COSMOS showing “rescan” option, which is supposed to mean it’s “done” scanning, alongside the blank, unattributed samples.
