Hi Waves Team,
i would like to ask for a separate TRIM for A and B Input in emotion lv1.
In case of changing the trim level, this change stays at the same level when switching from A to B input and produces there an offset. In case you only use mic gain, you can avoid trim level changes. Using LINE input on the IONIC or Classic console inputs which have only TRIM gain, you need to use the TRIM. Recording this signal using A input and playing it back with B Input adds the TRIM level a second time.
Having a separate TRIM level for A and B input when switching would help.
Kind regards
Michael
