anyone else have this issue? Where you install and Logic Pro says it’s not AU compatible? I’ve tried checking plugin task manager with a reset and rescan but it won’t open L4 live (s) or L4 live (m). Coming on here cause tech support basically told me to uninstall and reinstall. Didn’t help.
Yeah it’s working on my system. Did you try deleting your plugin cache when when you di a reset and rescan?? How about running the Repair option in Central’s Settings??
The other thing to check is whether it’s compatible with your version of Logic and OS…
They checked it remotely and said this:
To recap our conversation, the L4 Live component can only be loaded in WPAPI hosts, such as our SoundGrid apps SuperRack and LV1. It is the same as the normal component but without oversampling and true peak, and with lower latency values.
The L4 Live should not appear in DAWs.
We are aware of it and are working on a fix, though there is currently no ETA.
For now, you can ignore this and keep using the normal L4 Ultramaximizer.
Let me know if further assistance is needed.
Best regards,
Not needed to run and will be updated eventually
Thank you for helping!
Ah that makes so much sense now, given the context.
