eMotion LV1 v17.3.108 is out: stability, tempo and touch fixes
We just released eMotion LV1 v17.3.108.193 for all LV1 mixers, including LV1 Classic and modular systems. It’s a fixes and improvements update built around what you’ve been reporting since V17 launched.
What’s fixed and improved
  • Plugin stability: no more freezes or crashes when dragging plugins between channels, removing plugins from the rack, or opening plugin windows and menus.
  • Touchscreen faders: bigger fader touch targets, so faders are easier to grab and adjust.
  • Blank displays: fixed cases where an app or plugin window stopped drawing after long sessions, or a session stopped loading.
  • Stereo input assignment: CTRL + Touch on the input source menu in the Channel window now routes correctly.
  • Tempo: tapping the on-screen tap button now sets the correct tempo, and plugins on MON auxes follow the session tempo again.
  • Send pan: send pan values are kept when you switch send pick points through PSP.
Update through Waves Central. For LV1 Classic, follow the LV1 Classic update instructions.
It’s an important update for all V17 users! Let us know if you ran into any hurdles.
Hey Team , I updated one of my LV1 classic sets to the new version and did a show with it last Saturday.This version is even slower than the previous one and the freezes between the actions are still present. V16 was a very stable and fast version but since V17 I only experience problems. There are no audio drops (fortunately) but it is very annoying to have to mix like this.
I have already taken the following actions, emptying the memory, starting a complete new session,… all this has no influence on the problems.
Have you received any complaints since the release of this version and if so, when will there be an update where these problems will be out of the track?
Hi @jurgenvandewalle,
This needs a closer look from our live team. Please open a case with our tech support and it will be forwarded to them to check your setup.
